You can check out mine at school if you want....
I have installed the old style Recon clears on my white truck, (ones with incandescent bulbs)
I was pleased with the quality of these, I did have a problem with them yellowing after about 6 months, heard it was a common problem, and that Recon had made a new set with better material, called them up and they shipped a new set out for free, no problems since, thats been about 3 years. No leaks, etc.
I installed their newer LED style on my Dmax, SHITTTTTTY quality, material was much thinner, screws must have been made of aluminum or something, I replaced them all with stainless screws, and the two outers leaked. Finally fixed that with a big batch of silicone. The wiring was really small gauge (leds don't need much I know) and would have been fine if you were replacing factory lights as they had 194 bulb plugs on the wires, but for my case I was hard wiring them...well those small wires were too small to use with crimp on quick disconnect wires, so I wound up soldering them in.
Look good though....although I wish the center bar was ... ... ... rather than the solid ............. that it is
I also installed a set of OEM style Pacers on my brother's girlfriends truck, Quality of those were great, I was pleased. No leaks, etc. Similar to my original Recons, except no problem with fading etc.
