I'm hoping someone has had this same issue and can share what they have found, my truck is shaking badly starting at 1300 rpm and doesn't stop until around 1800 rpm. It doesn't matter if the truck is in gear or in park/neutral, the shake is still there (worse under load). I tune the truck myself with efi live but also have tunes from Duramax tuner and Idaho Rob that all do the same thing.
I pulled the inspection cover off of the trans bellhousing earlier and inspected the flexplate - I did not see any evidence of cracks or damage but at the moment I dont have anyone here to bar the engine over while I look. balance rates are all within spec in neutral and in drive, the readings are below. The weird thing is it feels like a misfire when it happens, I used the EFI LIVE scan tool earlier to cut each injector individually and see if there was little or no change with one. I felt a noticeable change when cutting each injector at idle, but when i raised idle to 1350 and cut cylinders the shaking actually smoothed out a little when i cut #6. I tried this several times with every injector and had the same results every time.
I've looked into several threads on this issue today and plan on checking the harmonic balancer and having someone bar the engine over while i look at the flexplate better this weekend. There is no noise associated with the shaking, only the vibration.
Any insight you can give is much appreciated.
These are the balance rates off my v2 read at idle in park:
1:1.8
2:1.1
3:0.9
4:-3.0
5:0.0
6:-1.4
7:1.5
8:-0.9
1:1.8
2:1.1
3:0.9
4:-3.0
5:0.0
6:-1.4
7:1.5
8:-0.9
