Back Pressure Gauge Questions
yellowchevy
1,904
53
Louisburg, KS for now
I finally got around to installing my boost, EGT, and back pressure gauges I got from Meyer performance this weekend. Which took me ALOT longer than I thought it would, but I think it turned out really good.
I tapped into my driver side manifold for the back pressure going through an air compressor filter(with copper line), from the suggestions I've seen online, to help it not jump around as much.
When first firing it up all seemed good, everything was working and there were no leeks, which is a plus ;)
Leaving the shop I noticed a loud ticking noise that got louder as I accelerate, almost louder than the turbo whistle. When idling you can just faintly hear it. I checked the air compressor filter drain and that was shut.
When I got to the highway and opened it up, my after intercooler boost was at 20 psi while my back pressure was dancing like crazy from 20 - 30 psi.
So my question is
1. What the heck is that ticking noise? I'm assuming it's coming from something related to the back pressure gauge but I'm not sure.
2. Is that normal for the back pressure gauge to dance back and forth so bad?
Any help is much appreciated. This is the first time dealing with back pressure so I'm not to sure.
If I have to listen to that ticking noise any more I'm going to rip off that back pressure line :mad::mad:
I attached some picture so show my line mount and gauges(because they look soooo good, haha) :thumb:
Thanks in advance
Yellowchevy
maine04max
Dec 11, 2008
1,009
My drive gauge doesn't jump around . I used 1/8 tube and then used a 4' brass pipe with adapters , steel wool lightly packed inside the tube . the tube you used looks big maybe that's the issue ?
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
i used 3/16ths brake line a reduceded it to 1/8th copper line before a
i entered the cab and went dirrectly on to the gauge without problem.My problem was i left it hooked up and went on 4 hour trip and i stated to get condin sation out of the gauge so i leave mine diconted till i need it.The gauges look good Russ:thumb:
yellowchevy
1,904
53
I'm assuming you came off the exhaust manifold then to the 4ft piece of brass pipe then back to the 1/8th nylon tube to the gauge?
What dia brass pipe?
If you think of it could you post a picture?
I used 1/4" copper tubing.
Yellowchevy
yellowchevy
1,904
53
Did reducing mine from 1/4" to 1/8" cause a problem or the air compressor filter?
How about the ticking? Did you guys notice a ticking noise once you installed the gauge?
Thanks for the complement blk smoke
Yellowchevy
maine04max
Dec 11, 2008
1,009
Sorry for the dirty engine bay . As you can see it has 4 feet of 1/8 copper from manifold up to that brass 3/4 pipe then I have a electric pressure sender that goes to gauge . you could just hook 1/8 plastic tube on the other end , by the time exhaust get thru 4 ft of copper tube its cooled down .
as too my original post sorry its 4 in not 4 ft on the brass pipe and the tubing is 4 ft to let it cool off , it was a long day when I posted
yellowchevy
1,904
53
try putting a little crimp in the copper line. that should help stop the bouncing.
I'll try that first, never thought about it.
I put the air filter on from reading it helped to remove condensation and eliminate the bouncing, but being I used 10 ft of 1/4" copper line it may have done nothing, haha :mad:
Thanks for the help guys. Maybe this weekend I'll be able to fix it, I'll report back.
Yellowchevy
Dirtymaxx03
3,110
Yellowchevy
the filter keeps the lines from getting clogged by the soot in the exhaust. a little kink in the copper tube should take care of the bouncing needle problem
yellowchevy
1,904
53
Wouldn't going from the 1/4" copper to the 1/8" nylon in the air filter do the same thing or is being there is so much volume going to the air filter that is causing problems?
Hopefully that stops the needle from bouncing and get rid of the ticking noise.
Yellowchevy
Dirtymaxx03
3,110
Yellowchevy
its probably not restricting the flow enough to keep the guage from bouncing, and are you sure that noise isnt a leak?
yellowchevy
1,904
53
That does make sense. I'll put some kinks in it up by the air filter and see what it does.
I'm not 100% it's not leaking.
When I started it up I let it run and checked the connections at the manifold along with the air filter and didn't find anything. I kicked it up to high idle to check as well and didn't notice anything.
I could spray soapy water on all the connections like doing to tires to see if anything bubbles form :dontknow:
I didn't check the connection at the gauges but I wasn't hearing anything in the cab like when my old boost gauge was leaking.
Yellowchevy
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
Usually ticking noise is an exhaust leak. I used 3' of 1/4 copper line. I use a oil pressure gauge and it's digital. Had a moisture problem with it so I put an inline filter to fix it
yellowchevy
1,904
53
It sounds different than your standard exhaust leak, it's hard to describe. I just drilled both manifolds while still on the engine, didn't remove them.
I haven't driven it much yet but the little I did there was no moisture in the air filter.
Yellowchevy
yellowchevy
1,904
53
Got a chance to look into this yesterday.
From talking to Rick(thanks again Rick :thumb:)the rattling sound was from the copper line hitting it's self. I Zip tied the coils together and that helped alot, it's not completely gone but much better. I'll look at separating the coils so they don't touch and then zip tie it to other items to keep it from moving.
I also crimped the copper line right before it goes into the air filter to calm the gauge down, about a 2in long spot. It's better but I'm going to crimp it a little more.
Yellowchevy
