so on the ol ladys truck one of the axle seals are leaking so i ordered 2 new seals from merchant but i cant find any info on tq specs and what axle socket i need anybody have any info or what all i need to do the job
I was told 50ft lbs by a few Dmax techs I trust
I was told by a gm tech not to grease the bearing because its oil fed...
well its not really a spec to stay at. bascially, a click at 50ft lbs, back off nut if the key way is not in line, and re install so its not really a toque spec, its just a way to preload and keep some preload when you back the nut off to get the key way to line up. bearings had no blueing from heat even after 100k doing this. snugging the axle nut, then backing off to put the key way in would tear seals up rather quickly.
Yes you are right I should have made myself clear. A thin film is fine what I meant was to not pack the bearing like a typical spindle bearing.
A thin film is what I meant, sorry. Packing them would be pointless and might gum things up. Never thought about jacking it up to let the oil drain I always just used the small dip across from the house.
