Anyone ID this?
Mogman
341
17
Papalote, TX
Does anyone know what transmission this is? or care to guess? (Sorry, I did not take this picture)
THANKS
Mogman
341
17
Papalote, TX
That is interesting, looking at the transfer case I was guessing it came out of a late model 3/4 or 1 ton gasser, Thanks for the input!!!!
Mogman
341
17
Papalote, TX
Thanks guys for the help, it turns out to be a 6L90 by the measurement of the main body, picked it up for $25 on a pallet from a closing machine shop sale.
It looks like it was pulled from a salvage vehicle as it has the transfer case and half of the front shaft attached, likely going to try as is if I can figure out how to attach it to a 6.2L diesel, the 0.667 final ratio will be better than the 0.75 of the 4L80E transmission being used in the late HMMWV trucks and should be more efficient than the earlier design (important with only 160HP)
Should make for an interesting swap...
It would have been better if it was a 6L80 though but you gotta play the cards you are dealt yes?
Mogman
341
17
Papalote, TX
It may take quite a bit of work since the TCM is inside the tranny on the valve body. You may need to swap valve body's or have some kinda special controller to run it.
There are at least one and possibly more companies selling a "stand alone controller" actually they say it is not because the controller is in the trans. but all that is absolutely necessary for operation is a TPS and RPM input, can be CAN or analog
http://www.zerogravityperformance.c...ic-transmission-controller-6l80e-6l90e-6l50e/
Not cheap but......
Benny315
Benny
Feb 11, 2019
86
3
Backwoods, Savannah, NY
Not cheap but......
Here's a thread about rebuilding 6l80/90 with pic's & parts links. Few pages in, tap shift set up and more.. https://www.pirate4x4.com/threads/how-to-rebuild-a-6l80-transmission-with-optional-upgrades.1588577/
Reactions: Mogman
