Allison Help
Dustin1016
May 23, 2015
Not sure if I have an Allison issue or Duramax issue? 2011 Chev 3500, driving emergency brake and ABS light came on. Shift indicator line went blank. Truck would not upshift, eventually insidcator light came back on and truck shifted normal. Now the indicator is off again, other 2 lights still on, truck hard going into reverse or drive, but when the shift indicator light is on it shifts smooth. Thinking possible TCM but unsure, and would TCM cause the other 2 lights to come on? Havent found any obvious wiring problems or damage.
Dustin1016
May 23, 2015
Is there a schematic available online? Troubleshooting tree for TCM? Unsure where all ground locations are to check. Never had any other symptoms or major issues and for all to happen at once was very odd.
