Since I completed the swap, I've had a few rail pressure problems. Over the weekend when I got it running, one time I started it, it sounded a bit loud, and it threw a "rail pressure too high" code. Rail pressure was around 10k @ idle. Shut it down and restarted and it was fine. Today, while driving I had a few instances where it fell on it's face. I did some watching of data and found that when it falls on it's face, the rail pressure is tanking. Which is the more likely culprit: Regulator or FPRV? right now it has the stock FPRV and regulator, but I have a race "valve" sittin gin my LLY rail for the moment. I also have a WD modded LBZ regulator in on my LLY CP3. Given the high rail pressure over the weekend, I'm leaning towards the regulator being "sticky". Thouhts?
On an unrelated note, I reset the fuel filter minder in the DIC and in like 10 miles it had reset to 0. Kinda strange.... Anyone seen that before?
