Blow shit up, they are a mean turbo.
I would recommend the 83mm turbine for it honestly as it will drive a lot nicer for you. Great small s400 turbo that drives ok and can make decent power also for a great price.:thumb:
http://www.danvilleperformance.com/borg-warner-cast-s468-83mm-t-4/
Just spoke with Jose at FI and he told me for he money just get a cast 467.7 that billet wouldn't get much improvement for the money. Any truth?
Correct, they are identical wheels other than cast vs. billet. If you were using it as the high pressure turbo in a big twins or triples then use the billet. Anything under 800hp and it's not worth the price difference on it.
Im running the S468 that Mark posted on stock fuel. Good all around fun turbo and I have also towed from 3k to 20k lbs. with it
I'll be running 60s and modded pump or duals should be fun
I ran a 68/83/90 on my lml, i had a billet wheel though and still blew it up one time lol, but I liked it.. Spooled good and will support some decent power..
Turbo for sure.. Shaft broke and the wheel went to little bits.. I was still on stock injectors so I wasn't worried about the engine to much..Blew up turbo or engine
