05 LLY Timing Gear Carnage
Blackbird1877
220
Hello again… It’s probably been 10+ years since I have been on here. So long I had to re-register with a new screen name.
On to the fun part. My truck died about 5 years ago and for lots of reasons I am just now trying to fix it. At the time I was driving around with a slight tick/knocking noise (think a small block Chevy with a valve that is out of adjustment) Driving down the road it finally just died. CP3 stopped pumping fuel because there are so many missing teeth on the drive gear.
The good part… the cam and crank gear stayed timed so the internals of the engine should be ok no piston valve contact etc
The parts I need help with Is it possible to remove the gear off the crankshaft while the crank is still in the block and the engine is still in the truck? Am I correct that there are no aftermarket gears available? I can’t seem to find any. Do I need to dig deeper and look to find what may have caused this, or do I just chalk it up to bad luck and me driving too long with a faulty gear in the timing drive system? Any recommendations on where to get all 3 gears? Is the dealership my only option?
Side note, does anyone do tuning anymore. I’m in the market for a tune if this thing gets running again
The truck
05 4 door long bed 4x4 LLY
Mods
Turbo back exhaust, Up pipes, Downpipe
complete EGR Delete
Head Gaskets ARP Studs
Garrett 4094 VVT
EFI Live with race tune
3,683
236
Makes me wonder if the CP3 started to seize up, causing it to rip the teeth off? I'd personally be inclined to replace the CP3 entirely, or at least find someone who can test it before putting it back in.
Blackbird1877
220
Yeah i was worried about that as well. Oh darn! I guess its time to ass some go fast parts to the shopping cart :ROFLMAO:
824
Contact Bdsankey on here. DDP was haveing a sale untill the 30th and he can get other brands like Exergy too!
KyleC4
470
Bay Area
Without a full tear down I wouldn’t guess at what happened. I mean you have to pull the crank anyway to replace the crank gear. And what I’d look at is the cam thrust plate for wear or the bolts being loose. Just cause the teeth at the rear of the cam gear and teeth at the front of the cp3 gear are damaged. That would seem to me like one part shifted and instead of having full teeth engagement it only caught the ends.
