Why no blowoff valves?
Pony Express
Back on the road
Dec 30, 2010
31
Southern CT
Hey folks,
I was just thinking the other day about blowoff valves and turbos. I know its kind of a ricer thing but it seems like turbo bark could spell trouble for a turbo so why don't most of the guys running the pulls and drag racing use blowoff valves? Or is it just that I am unaware of it?
I'm not 100% familiar with the inner workings of a turbo (as you can probably tell), but does a wastegate act sort of like a blowoff valve?
Thanks :thumb:
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
Id start with the fact that diesels dont have throttle plates, would they help in some situations on a diesel....yeah but no where near like on a gasser!
paint94979
Beer Nazi
Sep 18, 2006
11,714
diesel also have no Vacuum to operate blow off valves
BD makes a kit but its like $600
And it ties into the throttle position so it takes time to setup correctly... IMHO it is very easy to not bark a turbo
13,605
640
Some turbos bark much easier than others, and some people run a BOV on their truck. You can easily make a BOV that works off drive pressure.
Jetty LBZ
work in progress
Jan 24, 2011
404
33
middle TN
someone correct me if im wrong but im pretty sure that turbo bark puts a lot of stress on the shaft and its possible that it could brake it.
9,903
149
I guess if you never leave the pavement or do burn-outs.......:D
Most people run them off of drive pressure like Josh said. Not hard to set up at all either.
GeneralTJI
Turbo Todd
Jun 1, 2010
1,272
Colorado
Run a very soft spring in the BOV, drive pressure is higher than boost, pipe drive pressure into the BOV (after running it through some coiled up copper tubing) and it will keep it shut under a load. When you let off DP will nose dive and boost pressure will overcome the light spring and vent.
Ryan T
1,007
CA
when your doin 125mph at the end of the 1/4 in 7000lb its easier to just let off then start rollin outta the throttle, i put a bd blow off valve on my dodge and it stoped it from barking, it was very easy to set up.. but it wasnt easy on the wallet..it looked and sounded cool though!:thumb:
JustinD
Plow Truck
Nov 21, 2008
2,067
41
Tiverton Rhode Island
Thank you!:thumb:
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
Yes its very easy to control the throttle and not bark it. But I also drink and have my buddies drive me to taco bell in my truck at 2:30 in the morning. They do not know how to be easy on my truck haha.
I have a BOV hooked up on mine. Does its job at preventing bark a good 80% of the time and it is just another noise that makes my truck stand out a bit more haha. Mine was a Apexi BOV off of craigslist for $40. Had a buddy TIG weld it onto the intercooler cold pipe, ran some copper pipe to one side, tapped into the wastgate hose on the other side, slight BOV spring modifications and walla: Diesel BOV for about $55 and a case of beer :)
