i need help with a stock file efi. thank you.
R roachajerm New member Jan 18, 2024 4 0 1 Arizona Jan 18, 2024 #1 i need help with a stock file efi. thank you.
TheBac Why do I keep doing this? Staff member Apr 19, 2008 15,369 1,649 113 Mid Michigan Jan 18, 2024 #2 Moved into the Tune Library. Look in this section, there's a few LMM threads that may have what you're looking for.
2004LB7 Well-known member Dec 15, 2010 6,463 1,816 113 Norcal Jan 18, 2024 #3 If not I should have it. Do you have an OS number?
R roachajerm New member Jan 18, 2024 4 0 1 Arizona Jan 19, 2024 #4 2004LB7 said: If not I should have it. Do you have an OS number? Click to expand... 12628594 thank you
2004LB7 Well-known member Dec 15, 2010 6,463 1,816 113 Norcal Jan 19, 2024 #5 attached Attachments 12628594.zip 1.8 MB · Views: 6
R roachajerm New member Jan 18, 2024 4 0 1 Arizona Jan 20, 2024 #6 2004LB7 said: attached Click to expand... i cant open the file. its a TUN file? i tried changing to .ctz but it still wont open. thank you.
2004LB7 Well-known member Dec 15, 2010 6,463 1,816 113 Norcal Jan 20, 2024 #7 You might need to update your software. I can also upload a ctz file too
2004LB7 Well-known member Dec 15, 2010 6,463 1,816 113 Norcal Jan 20, 2024 #8 ctz version Attachments 2008 LMM 12628594.zip 1.4 MB · Views: 6
2004LB7 Well-known member Dec 15, 2010 6,463 1,816 113 Norcal Jan 20, 2024 #10 Make sure your fuel tank size is correct as well as tire size before loading it up
