Where Does the Dipstick end up?
Ron Nielson
684
114
Berryton, KS
The question is, "When the dipstick goes into the pan area, does it go into the front section of the pan (in front of the hump in the pan) where the oil will not drain out during an oil change, or into the rear section where the oil would drain out??"
1,723
You can see the dip stick just to the left of the pickup screen
That should put it to the right side bottom of the pan in this picture
stock3-jpg.959754
So to answer your question, it is in the oil that drains but not over the part that remains
Ron Nielson
684
114
Berryton, KS
Thank you. I was hoping there would be a very easy way to extract more of the 'old' oil. Makes the job a little harder because of this position.
clrussell
pro-procrastinator
Sep 23, 2013
5,906
363
If you’re that concerned about it get an aftermarket pan that solves this problem.
Ppe ot banana pan
Reactions: DAVe3283
