What does it take to turn 35's?
duramaximizer
#1 Abuse Enabler ;)
May 4, 2008
1,186
Edgerton, Ohio
I am stock as stock with a tune and a lift pump. What does it take to turn these tires in 3rd gear with proper rpms for truck pulling. Am I out of my mind for thinking I can turn these?
custom8726
2,784
Upstate N.Y
4.11's/4.56's,, or more power:) I have pulled with 35's and a stock turbo, fuel system and 3.73's and did pretty good at local pulls, but I think 33's are better suited for the factory 3.73's and 450 - 550 WHP.. There are a bunch of guy's on here with more Knowledge in the regards of sled pulling then I though so maybe they will chime in?
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
IMHO around ohio with 3.73's stock turbo, workstock setup i would much rather run a 35 for ground speed purposes than 33's although both will work good.
bubba2400
Jul 19, 2009
199
Union Grove, WI
Agree, I would run the 35's for ground speed. A lot of times 3rd gear and 33's you will max out the rpm going down the track where the 35's will give you more ground speed in the middle of the track. If you are going to drive on them you won't have to worry about them biting too hard at the big end of the track.
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
for workstock i would say you would want it anywhere from 3200-3800 rpms. anything over that and your not making power and just puting stress on the valve train.
bubba2400
Jul 19, 2009
199
Union Grove, WI
:thumb: Around 3800-4000rpm as long as you can get it that high. Like ecc said it will probably stop making power somewhere in the rpm range so it won't pull any higher.
Colt
Jul 23, 2010
523
About what RPM are you seeing stock push rods bending on the Duramax? Fleece is going to the chromemoly pushrods for their 454 for it's intial rev map from last article I saw. He wants to see big R's on that thing like 7k I think it was. I don't know if they can hold it together very long at that stress level. It's great to see them try.
duramaximizer
#1 Abuse Enabler ;)
May 4, 2008
1,186
Edgerton, Ohio
Ha, I tried 4th. Gulp.... There is a reason they call that HERO gear. ROL It went from 4500 and climbing to 2700 and I lost a ton of momentum. By the time it downshifted, it was way to late. The allison has a huge delay on the tapshift, it isn't instant like the older gear shift.
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
Trust me. It isn't instant on the old gear shift either. Ive tried it many times. Thats why I went with 4.56 gears and a TQ unlock switch
TNRGreene
Kicked to the Curb
Sep 2, 2006
2,911
Bradenton, Florida
about what rpm are you seeing stock push rods bending on the duramax? Fleece is going to the chromemoly pushrods for their 454 for it's intial rev map from last article i saw. He wants to see big r's on that thing like 7k i think it was. I don't know if they can hold it together very long at that stress level. It's great to see them try.
lol
