I see you have an LB7/LLY water pump listed with tigged impeller, but none for the LBZ. Do you not have one or am I just missing it (I see you have an electric setup for the LBZ but I'm looking for mechanical).
I tried to pin my water pump myself this afternoon. The shaft is so hard, I couldn't find a drill bit that would get the job done.
Not what I wanted to hear, I was going to try that too..
I milled a nice flat spot on the impeller for the drill bit and of course the cast iron impeller drills like butter. The bit ended up walking all over the shaft and just went all skiwampass making a mess of the flat spot. If i had a carbide end mill the proper diameter it probably would have worked just fine.
Guess I'll just spend the extra $ and order one from Danville.
