Is the 4094 the biggest turbine available?
whitey DIESEL NUT Dec 2, 2014 207 0 16 Minnesota Oct 16, 2015 #1 Is the 4094 the biggest turbine available?
DetailsUnlimited Active member Oct 26, 2009 1,264 0 36 Benton, Ar Oct 16, 2015 #2 Fleece cheetah is a 71. 68/71 it's what I have and selling
whitey DIESEL NUT Dec 2, 2014 207 0 16 Minnesota Oct 16, 2015 #3 What size is the 4094? What is the reason you are selling it?
Yellow Jacket WannaBe Sled Puller Feb 11, 2009 917 0 16 Waterloo, IA Oct 16, 2015 #4 Fleece uses a s400 turbine wheel machined to their specs, by Engineered Diesel....to my knowledge
DetailsUnlimited Active member Oct 26, 2009 1,264 0 36 Benton, Ar Oct 16, 2015 #5 I'm building a triple set up. The 71 is a inconel wheel. It's made to take more heat I think then the stock wheels they come with.
whitey DIESEL NUT Dec 2, 2014 207 0 16 Minnesota Oct 16, 2015 #6 Does the 4094 do a good job or would series forty two be better?
nwpadmax comlpete diphsit Aug 17, 2006 110 0 16 under my truck Oct 16, 2015 #7 Bigger VGTs exist...the question is, how big ya wanna go and how much effort do you want to put in? The 4094 is the largest "easy" solution.
whitey DIESEL NUT Dec 2, 2014 207 0 16 Minnesota Oct 16, 2015 #8 Don't want to do it. Just asking. Have Mark's R turbo.
ikeG Oughta Know Better Apr 19, 2011 2,428 128 63 Western PA www.facebook.com Oct 16, 2015 #9 I think Holset makes a HE531 or something of the sort. Huge variable. Off a medium duty semi engine
G gamudslinger88 New member Aug 26, 2011 322 0 0 Oct 19, 2015 #10 I was thinking the 4094vvt had a 77mm turbine. May be a 71mm though.
Yellow Jacket WannaBe Sled Puller Feb 11, 2009 917 0 16 Waterloo, IA Oct 19, 2015 #11 gamudslinger88 said: I was thinking the 4094vvt had a 77mm turbine. May be a 71mm though. Click to expand... I've never measured the inducer on turbine wheel....I would assume it's around 3"+ diameter, 68mm is exducer... Inconel s400 is 84mm inducer....I'm not sure if Fleece is removing material from inducer also, or not...
V valleyduramax Member Jul 25, 2010 231 4 18 Ottawa ON Canada Oct 19, 2015 #12 Are they still using the gt40 exhaust housing with the bigger wheels? How does the veins clear the bigger wheel?
paul06d-max New member Nov 18, 2010 36 0 0 Oct 22, 2015 #13 Yellow Jacket said: Fleece uses a s400 turbine wheel machined to their specs, by Engineered Diesel....to my knowledge Click to expand... We do not use a S4 turbine wheel in our VNT's, It is a shaft we have made to our specs with no S4 characteristics.
Yellow Jacket WannaBe Sled Puller Feb 11, 2009 917 0 16 Waterloo, IA Oct 22, 2015 #14 Hopefully it lasts better then the ones in the 63.5mm billet unit... What are those factory 40 series vgt turbines made of?
