Turbo vane position sensor
M.hulsey91
Apr 25, 2015
137
So I threw a CEL on my 05 lly and pulled up 5 codes. 3 of the 5 said turbo vane position sensor 1 said o2 sensor and the other said low voltage in circuit. Im new to diesel engines so all help is appreciated
M.hulsey91
Apr 25, 2015
137
P2564 p2563 p0046 and p2228 and p0652 are all 5 codes that were read before it went into limp mode
M.hulsey91
Apr 25, 2015
137
I've talked to several different places and is all leaning towards the turbo vane position sensor being bad. If not that then the ecu may have went to crap but i have the factory one still so there's a plus. Just aggravated that i can't drive it right now
duramaxnate
Professional Amateur
Feb 18, 2014
513
32
Norco, CA
www.mcfooracing.com
Vane position failure code is a p0003a.. Had that code pop up on me... When I see the 2563 code pop up on trucks usually the turbo vanes are getting stuck either intermittently or all the time.. Is this the first time this happened to the truck?
M.hulsey91
Apr 25, 2015
137
The sensor isnt covered by the warranty which sucks. Im gonna have the turbo checked tho because it is covered by the warranty
M.hulsey91
Apr 25, 2015
137
The dealer here wants $400 for sensor. Im prolly taking it to a shop monday and gonna have them do it. Idk waiting for dealer to call back
Drock
Apr 20, 2015
54
Garrison ND
I know the vps will. But the turbo might need some tuning. And North Dakota
yellowchevy
1,904
53
Louisburg, KS for now
If you hook up a tech 2 or V2 you can look at desired vs. actual vane position thats an easy way to tell if something is wrong.
I sell new sensors for $350 shipped if you need one.
Yellowchevy
