Starting in 1991, new designs were to implement a new designation system, but not all tire companies complied, so there are two systems in use with the new tire markings as the preferred system.
Old System:
225/50SR16 - 112mph
225/50HR16 - 130mph
225/50VR16 - over 130mph (unspecified test speed)
225/50ZR16 - over 149mph (unspecified test speed)
The new system has a two part designation, the first part is the size only:
225/50R16 - 225mm inflated width, 50% height to width ratio, radial, 16" rim.
the second part of the designation is a number and a letter, with the number being the weight rating, and the letter being the speed rating:
100W - 1764lb (800kg) + 168mph
So the full marking on the tire would be 225/50R16 100W, and would be the new designation for the old 225/50ZR16.
The weight numbers are:
And the Speed Letters are:
M 81 mph 130 km/h
N 87 mph 140km/h
P 93 mph 150 km/h
Q 99 mph 160 km/h
R 106 mph 170 km/h
S 112 mph 180 km/h
T 118 mph 190 km/h
U 124 mph 200 km/h
H 130 mph 210 km/h
V 149 mph 240 km/h
W 168 mph 270 km/h
Y 186 mph 300 km/h
(Y) over 186 mph (unspecified)
Often tires that are W, Y, (Y) will have the old ZR inside the tire size, but not always. Both 225/50ZR16 87W & 225/50R16 87W are the same.
So on tires that do not have a VR or ZR sequence in the tire size notation, you look at the Weight+Speed designation to get the tire's speed rating (and load rating).
copied and paraphrased from http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=35
Old System:
225/50SR16 - 112mph
225/50HR16 - 130mph
Code:
# LB kg # LB kg
71 761 345 91 1356 615
72 783 355 92 1389 630
73 805 365 93 1433 650
74 827 375 94 1477 670
75 853 387 95 1521 690
76 882 400 96 1565 710
77 908 412 97 1609 730
78 937 425 98 1653 750
79 963 437 99 1709 775
80 992 450 100 1764 800
81 1019 462 101 1819 825
82 1047 475 102 1874 850
83 1074 487 103 1929 875
84 1102 500 104 1984 900
85 1135 515 105 2039 925
86 1168 530 106 2094 950
87 1201 545 107 2149 975
88 1235 560 108 2205 1000
89 1279 580 109 2271 1030
90 1323 600 110 2337 1060
etc
M 81 mph 130 km/h
N 87 mph 140km/h
P 93 mph 150 km/h
Q 99 mph 160 km/h
R 106 mph 170 km/h
S 112 mph 180 km/h
T 118 mph 190 km/h
U 124 mph 200 km/h
H 130 mph 210 km/h
V 149 mph 240 km/h
W 168 mph 270 km/h
Y 186 mph 300 km/h
