Think i toasted my trans today
pavetim
299
5
I figured my 4-5 or 5-6 clutches were slipping cause towing my boat if you let it downshift and just go it would shudder the whole truck really bad. I just take it easy but today I had to pull over on the highway and when I went to take off I thought the wheels were spinning bit I heard a weird noise and my cell came on, got a p0700 and p0732 codes so guess I toasted my c2 pack? I think u might go with a goerend kit but have to see price of install. If it's a lot of money I might be easier to drive to suncoast and but a whole Trans already built.
Bdsankey
3,906
1,074
Neenah, Wisconsin
What's generation truck? The forum section you're posting in is generic and you have no info as to what generation you have.
I can upload a PID list/quick setup that will have everything you need PID and controller wise.
15,686
C2 clutch is 4th gear. C4 clutch is second. It is rare to see P0732. Maybe transfer case.
pavetim
299
5
Transfer case can make Trans feel like it's slipping? Cause yesterday the rpm went up that's why I thought tires were spinning but I guess it was something slipping, then it cranked, set that code and stayed in a gear idk what gear 50mph 3000 rpm so third gear? I pulled over in a few miles shut off and cel was still there but truck shifted fine, of course I took it really easy. I can check with my efilive once I know what pids to run
pavetim
299
5
Testing the Trans should be easy I can log rpm, selected gear, input and output speeds and see if it slips. How do I check the converter, it's job is to slip until it locks up so what can I do to check that?
pavetim
299
5
Will have to tow boat and log to see if it acts up, i drove truck today spiritfully and seemed to run good. But i do think trans is bad, allison with 75000 miles and transynd change 25000 miles ago shouldnt look like this
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,028
240
At Da Beach
When a converter goes bad it shudders like crazy trying to lock up under load. If it only does it under load when trying to lock up you have your answer.
Reactions: Bdsankey
