Stuck injector any ideas?
jraymer
<--Tree Hugger
Oct 31, 2008
1,421
Las Vegas, NV
05 lly pulling heads for head gaskets. Injector 7, the one in the back on pass. side is stuck in the damn hole. Any ideas on how to get it out? have been prying and tapping and spraying with penetrating oil with no luck. All the others popped out with ease, this one is being a serious bitch.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
i try to turn em side to side a little and pull up at the same time If its all gumed and sooted up try carb cleaner.Do you have the head off? or is it still on the truck?
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Cant get the head off till the injectors out. Lower valve cover still has one bolt under that injector, and you can't get to all the head bolts till the lower valve cover is removed.
Burn Down
Sep 14, 2008
7,093
Boise Idaho
I had to put the injector line back on so I had something to pry against. Pry'ed back and forth on the fuel line & valve cover, also held up pressure between the head & the hold down with another pry bar. Took me 4 or 5 hours to get it out & mine was number 1... I so don't envy you! Good luck.
jraymer
<--Tree Hugger
Oct 31, 2008
1,421
Las Vegas, NV
Yea that what I did, put the fuel line bak on so I could pry on something without destroying the threads. We can get it to move back and forth but even that takes a lot of pressure. Maybe I will bring my carb cleaner up there and just keep working it
Burn Down
Sep 14, 2008
7,093
Boise Idaho
This is what mine looked like after it came out. Notice the black pits around the copper seal. The dealer left carbon bits in the hole when they changed them. This injector only had 2,000 miles on it when I pulled it to do tips.
[/IMG]
jraymer
<--Tree Hugger
Oct 31, 2008
1,421
Las Vegas, NV
Damn, yeah I'm afraid that is what this one will look like. We broke the hold down from prying so much so we will see what happens tomorrow. May try to attach a slide hammer to it some how.
duramatt05
Nov 21, 2010
179
sunderland, Ont
I had the same problem with 5 and 7 injectors when I did my gaskets about a month ago. It took probly a good 10 hrs to get the two out. Bent both of the hold downs but after a lot of penetrating oil, prying and twisting with some channel locks they finally came. Put the hold downs in the press and straightened em out and they workin good now!
Burn Down
Sep 14, 2008
7,093
Boise Idaho
You can sacrifice a injector line. Cut the line and pull the nut off, weld it to a cheap wobble impact socket, weld a nut to the other end that will thread into a slide hammer. I have one built for pulling cat nozzles. I just didn't have access to it when I pulled mine & I was pissed at it, so it either was either cummin or bleeding!
jraymer
<--Tree Hugger
Oct 31, 2008
1,421
Las Vegas, NV
Well we finally got it out tonight. One guy prying up on it and one prying sideways rotating the injector in the hole. Tons of debris in the hole, almost looked like rust.
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
Another day of fighting with it and you would of been doing the same thing.
I know how you work too.:roflmao:
jraymer
<--Tree Hugger
Oct 31, 2008
1,421
Las Vegas, NV
Copper ring actually didnt look that bad, it was stuck down in the head though. All the other came out with the injectors. I will take a photo of it today .
