Stock tune resources
408
I found a link to a drop box account a few years back. Not sure if it is the same one. Because of the instability of various sites and links that host these type of files, I downloaded everything. For those who have the capability I recommend you do too.
So, is there any chance of hosting any of them here?
408
would these tunes even be trustworthy?
All tunes are "use at your own risk". The stock tunes are likely the least risky. If the checksum matches the factory calibration then it is low risk. But loading tunes always comes with risk even if it's stock
GMC_2002_Dmax
The Still Master
If you attempt to load a DSP5 file for an LB7 or LLY or a Cummins CM2100 and do not know the source file is "CLEAN"..........you are rolling the dice the ECM may brick.
Aftermarket tuners leave "STAINS" so any file that is not 100% stock and never tuned/turned back to stock can cause issues.
Take this for what its worth.
