SoCal Diesel Super Damper
ripmf666
15,123
14
47
Wentzville Mo
LB7, LLY $457.10 + Shipping
LBZ and LMM $457.10 + Shipping
Duramax Super Damper
Don’t confuse this with “Viscous Fluid” designs that weigh 5 lbs more than stock and cause more damage to the weak 5mm drive pins on the snout of the Duramax crank.
This Elastomer Design is used by professional racers in NASCAR and NHRA.
• SoCal Diesel is proud to introduce the Super Damper for GM Duramax Diesel Engines.
• The Super Damper provides balanced dampening of torsional crankshaft vibrations at all RPM.
•The Super Damper comes with laser-etched degree marks and is a direct replacement for the stock OEM unit.
• The SoCal Diesel Super Damper is especially needed in high performance and modified trucks to help protect against harmful engine harmonics.
• All SoCal Diesel Super Dampers exceed SFI 18.1 Safety Certification and are approved for competition use.
• 3 piece design allows the hub, outer ring and counter weights to be serviced in the field.
ripmf666
15,123
14
47
Wentzville Mo
Shit I'm set on black and gray setting lol fix it later iPhone will not let me.
skintback
Take this one to church
Mar 5, 2007
919
Florida
Doesn't this require a install tool kit of some sort
A big hammer :joker:
