Not sure if this is the correct place to post this, but starting to think that maybe my set up is wrong for what I am trying to achieve.
I've been battling trying to make my truck run clean under 1/4 throttle or simply taking off from a light. I am on my 15th revision with a known tuner and starting to think its more of my set up.. Wanted some opinions on whether you think my truck should be able to run clean under 1/4 throttle or low boost conditions. No matter how hard I try once the engine is warm we cannot seem to clear up that "puff" of smoke leaving lights. It seems to be ALOT better during the cooler mornings and when the engine is cold.
Set up:
- Oval pistons at 16.5CR with valve cut outs (0.005-0.007 protrusion, running C gasket)
- Waglers stage 1 cam and ported heads
- S&S 100 over injectors
- Suncoast 1058 converter
- Danville 68/68 over a S483
- I live at 3500' elevation..
I did a fair amount of research and thought I would be safe running a some what clean tune under mild throttle conditions with this set up. Am I wrong? How clean of a tune are others getting with 100 over injectors? I wouldn't consider Danvilles STG2R 68mm a large turbo, but maybe I am wrong again.
Truck response is decent and cleans out nice when boost comes on.
Next step is to go down a size in injectors. Thoughts?
Thanks
Set up:
Thanks
