Hey guys so Saturday morning I went to a buddies house to change the tcase fluids. Truck has 167k on it and seems like it's never been serviced because the atf was black and thin. I reserviced it through the speed sensor hole with 3 qts of 5w30 mobile 1 synthetic. Went to leave and the truck pops out of gear as I pull on the road and message pops up saying shift range inhibited. It goes into drive and reverse just fine but as soon as I get going it won't shift out of 1st gear, spedo doesn't register and soon get the same message and pops out of gear. I replaced the VSS this morning and no luck. Same issues. I tried driving around the back roads slowly to try and get the mil to appear but nothing. No codes. Then I pull the connector for the pass though connector on the passangerside of the trans and the connector is wet with atf. I blew it out with electronics cleaner and put in a little dielectric grease to isolate the pins from the fluid seeping through and still same results. I cleaned the connections on the tcm also. Since I bought the truck the abs light has been on, code says front left and right circuit fail.
