Shift knob
SecondGenDura_man
'02 3500 w/Srvc Bed
Feb 9, 2020
1586994075560648475986005870412.jpgSo, I ended up adding a copper extension for about 1.5, maybe 1.75 inches. It's just enough to be more comfortable at my perfect driving position. The outer plastic is injection molded around a honeycombed hard plastic center piece that's press fit on using epoxy. I used a heat gun and the hard plastic knob came off with very little fuss. I stepped down my copper bar and grooved the end so that it fit easily into the stock shaft, which is hollow. I threaded three set screws to hold the copper piece firmly in place and thread sealed them with red thread seal. After that I just press fit an aftermarket knob that I had leather wrapped myself. I cut off the end of the set screws and made a leather sleeve to transition from stock to my extension. All in all about three hours of work and it was all done in my driveway with a dremel and a tap set. Not the easiest way to do it, but i really like the result.
Jadetrost
Mar 25, 2024
3
Bronx, NY
I have an 02 Duramax with the ZF-6 and I want to change my gear shift knob. I'd like to put a Hurst T handle on it just bc I think they look cool. But nobody seems to know how to get the factory knob off :(. I've looked online and seen where people have cut and welded to their shifters, and I can do that if I need to but there has to be a way to get this thing off! :confused:. Anybody have any ideas?? I've called a couple dealerships but they weren't any help, go figure. So I am at a loss, hopefully this great sight will help me out!:thumb:
Looks nice except for the splines that still show there...that would drive me nuts!
