"Service four wheel drive"
what would cause truck to die in reverse, saying service for wheel drive
  • service four wheel drive
    Votes: 0 0.0%
  • Dies in reverse
    Votes: 1 100.0%
  • Total voters
  • Poll closed .
Redneck0816
Apr 21, 2020
OK, so I've got an 08, 159,300 miles.. started out when I'd put it in reverse, it would run really rough and die within a second or 2.. at the same time it says to service four wheel drive.. it was running fine in drive, then it got to where it would die going down the road.. seen a pattern of mainly when you let off the throttle and it was idling down/ downshifting.. it will idle fine in park or neutral, I changed the transfer case motor, and that did not fix it. Any suggestions at all would be GREATLY appreciated.. thanks in advance!
Redneck0816
Apr 21, 2020
The check engine light is not on, it pops up on the dash "service four wheel drive" I've got a scanner coming tomorrow to plug in and see what that shows
