P2510 U1301 electrical gremlins
06DDLBZ
Mar 13, 2017
Dropped motor in recently, fighting electrical gremlins.
Truck was arc’d with a battery cable.....Battery light stays on when truck is off. When truck is cranked battery light goes away. Did have to reprogram a new TCM due to arc.. New alternator. New batteries. Checked all grounds. Truck cranks runs good, but is stuck in park. Trans freshly restacked. Also had a glow plug 8 code that has been cleared and gone.
From Tech2:
P2510- engine control ignition relay feedback circuit
U1301- class 2 communication circuit high
Any ideas on how to approach this? I’m not sure if there is a chaffed wire somewhere or if maybe I have a bad ecm from the arc? I put a multimeter on the fuses and I can’t find any parasitic draws.
06DDLBZ
Mar 13, 2017
The problem was eight cut wires in the harness under the driver side fender near the bottom of the windshield wiper fluid tank. I believe the cause was when the motor was pulled the cab was removed and set down on the wires.
