oil sumps
RickDLance
1,276
14
I'm working on the oil pan for my drag car and I noticed I have 2 different kinds of pickups.
One is rectangular tube and one is round tube. Anyone know when they switched to the round??
kidturbo
Piston Tester
Jul 21, 2010
2,306
1,068
Somewhere On The Ohio
www.marinemods.us
Lml pump. Larger dia squirters also.
Just buttoning mine back up today.
Sent from my SAMSUNG-SM-G890A using Tapatalk
kidturbo
Piston Tester
Jul 21, 2010
2,306
1,068
www.marinemods.us
It's a good bit larger actually. There is a thread on here discussing the differences.
Only issue is, the lml pump is thicker than previous years and requires some machining to fit lbz/lmm front cover as I did. Or you can run lml pan and cover, theb modify hub on damper as I did on another engine. But I find no good reason NOT to run the LML pump and squirters on any performance build.
kidturbo
Piston Tester
Jul 21, 2010
2,306
1,068
www.marinemods.us
Yeah you can easily remove all 8 rods. Even check 3 of the mains with upper on.
I modify these pans from front to rear sump for marine setups. Holds 15qrts in lower. Best design by far if ya don't have to clear a front axle..
