Oil feed restrictor for ball bearing turbo?
ZachM54
Mar 7, 2017
13
3
Kalispell, MT
Finishing up new gtx4294r setup and curious if I need to be running a restricted oil feed fitting. Been reading that ball bearing turbos tend to like less oil than a journal bearing but I don't have any real experience. Here's an old mockup pic
Thanks
juddski88
Freedom Diesel
Jul 1, 2008
4,651
116
Chesterfield, Mass.
Google is your friend...
Straight off Garrett's website,
"An oil restrictor is recommended for optimal performance with ball bearing turbochargers. Oil pressure of 40 – 45 psi at maximum engine speed is recommended to prevent damage to the turbocharger’s internals. In order to achieve this pressure, a restrictor with a 0.040” orifice will normally suffice, but you should always verify the oil pressure entering the turbo after the restrictor to ensure the components function properly. Recommended oil feed is -3AN or -4AN line or hose/tubing with a similar ID."
