NO POWER TO LB7 INJECTORS
autospecialty
Feb 22, 2021
12
Need some help. 2003 Duramax 2500hd LB7/ Allison4 weeks ago came everything running fine. Next morning it cranks but will not start. Fast forward. Checked all circuits has no codes, communicates with all modules. VTD works proper. Injectors not getting power from FICM. Engine runs via manually injecting fuel. All power and grounds going to all modules good. Communicates good.
autospecialty
Feb 22, 2021
12
We injected diesel starting fluid into the intake runner port to make sure we did not have a engine mechanical issue. (Yes, we disarmed the glow plug and intake heater)
autospecialty
Feb 22, 2021
12
What do you mean by engine runs manually injecting fuel?
We injected diesel starting fluid into the intake runner port to make sure we did not have a mechanical issue. We did disarm cold start system as you should to do this.
