I tried starting my truck and it didnt go the first crank so i tried again it started for 5 seconds then died, i found fuel leaking out the bottom the fuel filter and found the bottom piece on the filter had popped off i tightened it up again primed it and tried to start it again would crank but no ignition
If you could help me out it would be appreciated
its about -15 C here if that helps
