Mysterious oil leak?
Big_rig204
Nov 16, 2022
17
this morning when leaving for work saw small patches on the ground.. then getting under the truck saw this.. have no idea what it could be looks like oil but not sure.. all levels are good
Truck has 180k tuned and deleted
1,728
Remove the inspection cover in the bell housing and see if there is transmission fluid in there
4,863
most likely a gnome getting up in there and spraying it down with oil.... little bastards
4,863
Well any better idea then just a gnome?
its your truck my man, you will need to get in there and look. that little pic gives us about as much info as i gave you.
leaks follow gravity, get under there and start following the leak up with a flashlight till it its dry. you will have to determind what fluid it is, where its coming from and then take a pic of said part its leaking from. we can identify that part from there.
