Mileage issues?
vinnyd_lb7
Dec 25, 2020
9
hey guys, just recently made a 400 mile trip towing a 28ft trailer. the toughest climb was about 4000 feet. after reading some of your guys milage im starting to think something isn't adding up. I do have a 6" lift on 33" tires and would normally average about 15-16 but i got 8.5 towing. do these numbers sound right?
Bdsankey
3,906
1,074
Neenah, Wisconsin
Keep in mind this thread you're commenting on is 8yrs old.......................
What weight? what speed? What object (camper, gooseneck, deckover trailer etc).
vinnyd_lb7
Dec 25, 2020
9
oh i didn't notice that, if you couldn't tell im new to this.
no more then 8000#s doing about 65-70, its just a bumper pull.
Bdsankey
3,906
1,074
Neenah, Wisconsin
A bumper pull what? A bumper pull 8,000lb camper is way worse on economy than say a 8,000lb car trailer with a small pickup or a bunch of side by sides on it.
rcr1978
790
Spring Creek, NV
Yup it's all about wind resistance, that camper is a big o'l wind sail. Tire's and the lift definately are not helping either, there might be about 1/2-1mpg to be gained if your lucky with a good tune. 8.5-10 hauling wide/tall enclosed trailers, campers, 5th wheel trailers ect is the norm.
vinnyd_lb7
Dec 25, 2020
9
yes a bumper pull camper. does 8mpg sound reasonable. seems pretty low for me or i would at least like to get a little better. if they are any tricks, parts, or ideas to get a little better milage i would love to hear. thanks for your time.
vinnyd_lb7
Dec 25, 2020
9
Thanks for your reply. the truck and trailer are pretty close in height. i towed empty so im concerned with water and everything else going on a trip that the number could still drop. just trying to maximize what i can. with 26g fuel tank plus i carry 10 more gallons it seem i would like to go more then 300 miles lol
rcr1978
790
Spring Creek, NV
Weight does not make a big deference hauling it's the wind resistance thats the killer. Example I have 8.5x16 enclosed trailer that's 2ft taller for a sxs probably weighs 2500lbs unloaded. It get within 1-2 mpg hauling that thing around by itself vs hauling my 5th wheel with that same trailer behind it hauling doubles with a sxs in it. Total setup probably 16k vs the 2500lbs huge windsail of a enclosed trailer. Also LB7's do best in the 60-70mph area, over 70 in goes down fast this also applies to not having a trailer.
vinnyd_lb7
Dec 25, 2020
9
thats great info to know. I will definitely keep that in mind on the next trip. other then a tune and the speed are there things you do to maximize fuel milage?
I appreciate all the help and info. Cheers!
