Question: Metal shavings in the differential? Pics incl.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Just put on my Mag-Hytec diff cover and made sure to clean out the inside with brake cleaner really well.
The new cover has a dipstick in it with a magnet on the stick.
I checked the stick today, one day after the install to find a bunch of shavings on it.
Any insight?
[/IMG]
[/IMG]
9,903
149
Doesn't look that bad to me. As long as there are no big pieces when you drain the oil you should be ok. I have seen brand new ones with more crap in them than that!!
dmaxlover
Mar 17, 2007
453
WI
If your running a lot of power, the drivers side carrier bearing takes a ton of thrust, and the bearing doesn't last too long. After a season of truck pulling when I pull out my Mag-hytec dipstick, it looks like a lolly pop. I have some pics somewhere showing the junk bearing. I'll see if I can find them.
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Not one days worth of metal SS... you werent able to clean the backside of the gears (what wasnt facing the rear and visible) so once you moved the truck and the gears rotated some was probably dislodged. Nothin to worry about imo.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
I cleaned it off and will check it in a wek or so and report back here...
As long as there arent chunks in there im not sweating too profusely.
