Machine Down!
Fingers
Village Idiot
1,711
82
White Oak, PA
Covers off the VF-3. Several issues all at once. Machine Down!
High/Low Gear sensor flaking out. Might require removing the motor and transmission to get to the SOB since it is under the transmission, under the motor. Main Coolant line feeding the head has a big split in the Cat Trac. Wonder why the coolant was coming from behind the cover. Purge line fittings were all loose and one fell out. Easiest fix of the three.
For now the gear range sensor is hot wired to keep me going, but I can't put the covers back on till it is fixed.
