LMM water pump replace?
Mogman
311
14
Papalote, TX
The factory Delco pump did not come with the o ring for the end of the oil cooler pipe, do I ignore it and move on or do I trip up to the GM dealer and try to order one?
438
If you think you can get the old one back in without cutting it, go for it. Most times they are swollen and either don’t go in or cut themselves as they go in.
Mogman
311
14
Papalote, TX
I have not pulled the tube yet, the one on the top of the bypass tube was so swollen it literally just fell off of the pipe, I am going to town to see if the local chevy dealer has one before I pull it.
272
The top one is the one I was talking about. If the LMM pipe setup is the same as the LB7, you can use an LB7 injector cup O-ring if need be.
Mogman
311
14
Papalote, TX
NO WONDER that o ring is not in the kit $32, those folks at GM are GD thieves!! I guess what I would expect from an auto company owned by BHO
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
