and set the boost table to 30psi or so in the corresponding cells to the vane cells. LMM's will acheive the desired boost that is in the stock boost table in the higher rpm cells of the boost table by doing the exhaust brake function when you are decelerating so you have to raise the boost to an unachievablelevel to make the turbo keep try to make the boost by closing the vanes.
So you only do it on turbo vane position "C"?
somebody will probly get it before I do but when i get home if its not fixed then I will.
table b2225 set the minimum to 95 with 0 mm3 from 1600rpm to 3600rpm. try that
