Lmm allison fluid change
Idahodmax
Dec 22, 2015
51
So after much neglect its tine to change my fluid in my transmission, im just curious what everyone is running for fluids and if i should just drain and fill and change the external filter or drain fill and drive a few days and drain an fill an change external filter and how much fluid does it take for a fill.
Poor tranny has 126k, this winter im planning just changing all fluids, t case rear diff power steering ect.
1,732
I use Transynd. I would drain and fill and change the external filter. If the fluid looked really bad then I would pull the pan and change the external filter
BoiseRob
392
Where do you buy it, everywhere i find it online is like 48$+ a gallon
ATP sells it or Smith Power Products down by the Boise Airport is the local Allison dealer. You can also pick up a spin-on filter for around $8 while you're there.
Another alternative is Delvac 1 ATF that you can find at any truck stop. It too is a TES-295 approved fluid.
Of course, I'm assuming you're in or near the Treasure Valley...
https://www.atptrucks.com/
https://smithpowerproducts.com/
