LMM: LMM 900-1000hp build
lmmcbrown0917
159
North Carolina
Almost time to start ordering parts for this motor build.
Build list:
Bored .020 over
Carillos
20 over Mahle cast pistons 16:5 CR, .075 pockets
Head studs/Main studs
Keyed stock crank
Empire stage 2 AF cam, keyed
Fluidampr
Hamilton valve springs
Hamilton push rods
Stock heads with a valve job
Dual stock Cp3s
100% over exergys
Danville 72 vgt/S483 twins
Tuning from Mark
Im sure I'm forgetting some little things
Hoping for 900-1000hp and 10s on fuel!!
1,594
Sounds like you have a good plan, other than the particulars...but the others have you covered.
Above all....have fun building it. Ain't worth it if it isnt fun.
kidturbo
Piston Tester
Jul 21, 2010
2,302
1,056
Somewhere On The Ohio
www.marinemods.us
Whats the main difference between Finger's pistons and the new low compression Mahle with graphite skirt coating and valve reliefs? I liked the Mahle's, holding well at 650+ and extended time over 1500f.
Only suggestion I would add is drill out the oiler tips, helps piston cooling and gives extra lube to wrist pins.
