I guess to answer your question more directly. if the dimensions of the intake where the MAF samples the air deviate from stock the MAF will need to be rescaled
Fully warmed up LMLs at stock idle speed (with no EGR active), I usually see around 30-35 g/sec at idle. If you do a proportional scale to get your MAF rate there, it should be close enough.
