lbz van thermostat conversion
Yngdmax92
962
long story short. i bought a van thermostat housing used. It doesn't have the port in the back for the thermostat valve for the turbo line. I had the throught of drilling, tapping and adding in a port to allow a 3/8" of a line to go from turbo to thermostat. Question is, can i just delete the thermostat for the turbo? and run it straight? Have a 3794 for a turbo so it does need the coolant. What are your guy's thoughts of this?
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,774
Des Moines, Iowa
Does it bolt on? I am by no means a expert, but I was under the impression that if it has the bung for the turbo coolent it's a van housing and if it doesnt have it then it's a lml housing. I thought that the lml housing doesn't fit the earlier coolent bridge. Either way I am in for the information.
ZeroGravity58
1,382
46
Maryland
All the van thermostat housings I've put in are threaded in the back. What I can tell you is the HSP kit I have on my lmm just has a barb welded to the back with no thermostat. I don't see the problem drilling and tapping it
juddski88
Freedom Diesel
Jul 1, 2008
4,651
116
Chesterfield, Mass.
I may be wrong, but I believe the reason there is a thermostatic valve supplying the turbo is to reduce the amount of time cold oil is flowing through the turbo housing. The clearances in the turbo are relatively tight and thicker oil doesn't work well for the stock turbos. I think that proper temperature control and lubrication control of any other turbo housing requires a little more data collection and tweeking on a case by case basis.
Yngdmax92
962
Well shoot, I may have gotten sold a lml thermostat housing. I'll post up a picture shortly.
Yngdmax92
962
Maybe it is a lml. Idk doesn't have the side ports though
Nate’s Dmax
176
41
Yes that is a LML housing or maybe a LGH van housing now that i think about it. I have the 4094 with the van thermostat housing and eliminated the turbo thermostat by putting plug in that i drilled and threaded for a hose barb.
