Is anyone else experiencing this issue:
• Rail pressure will not go past 12.5K PSI when desired
is 26K PSI
• Will stay like this for a day or two
• Happens only when drag racing or driving around
under WOT conditions
Haven’t done the bottle test to completely rule out the possibility of a weak FPRV; I guess that would need to be the first step. What I find the most puzzling is it only comes up (most often) after drag racing. It is real aggravating when driving around with half power and to the best of my knowledge, lift pumps are doing their job.
Would a weak/heading south CP3 cause this kind of problem? I’m leaning towards changing out the regulator with a modified one and taking my chances of that being the culprit.
Any input would be greatly appreciated.
Thanks!
is 26K PSI
Thanks!
