LBZ EGR Delete...
ripmf666
15,123
14
47
Wentzville Mo
I'll call later today at chat with Dan, I think it realy only helps the LBZ guys out the most makes are intake come in like the Lb7 and able to geta better supply into the turbo and move that gride heater out of the way.
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
59
Norco, CA
wonder if it can be adapted to the o4/05 LLY's, could you get some more information on this Kat?
PPE does not have a delete kit for the LBZ. Dan says for turbo installs they just usually hack them up than weld a plate.
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
57
San Angelo
Weld the 2 ports shut on the bottom of the intake riser and set it back on the egr motor "for support only", re-route the coolant hose that went to the cooler, and block the up-pipe or install the federal pipe.
