I have a 2002 2500 chevy with 6.6 lb7. Injectors replaced about 10k miles ago. No fuel in oil. Heater hose broke on the firewall blew antifreeze in the ficm. Dried it out for it back running. Took it on a trip today the truck has no power. Surging going down the road. At idle I can hear injectors change tones. Has a slight duel knock I can make go away if I back fuel pressure down at idle with tech 2. Replaced the ficm. Still have all the symptoms. Pics are with truck warm and at idle. Possiably a fuel pressure regulator or relief valve. Also desired fuel pressure at idle jumps from 4900 to 5600. Has code p0094. Has a long crank to get running. Soon as I cut motor off the actual pressure drops to 158psi
