iDash not displaying option for transmission temp in menu
pinkmist
Feb 21, 2021
I don't get an option in the temp section of the iDash menu for transmission temp (also the trans temp isn't elsewhere in the menu either). I got all my other parameters set, but trans temp is one I definitely want, and iDash shows in the parameter list it typically reads it
The unit came with the latest firmware, 1.20.1, but I updated it anyway after not finding the trans temp option and still no trans temp. I have contacted Banks via email, but no answer yet. I thought I would ask if any of you have had this problem and what was the fix.
My ScanGauge2 read transmission temp before I replaced it with the iDash, so the data is there.
My truck is a 2021 Silverado with the L5P. Thanks for any help...
tbrowne
Dec 5, 2010
5
The iDash Trans Temp Option is labeled TRNS T on the Temerature menu. Not sure why you wouldn't have it unless you didn't recognize it when you went past it.
FreedomOne
Sep 30, 2020
3
Go into settings and vehicle select and set it as L5p and trans temp and your regen options will be added.
