I can't decide!!!
dman777
Apr 11, 2012
283
I have been reading so much info about converters I feel like my eyes are bleeding and I still can't decide which converter I want to go with! Stuck between 1058 and 1056. I will be using stock charger for the near future but I want to eventually go compound s475/stock. I like the 1058 but is it too loose for a stock charger/daily driver? Which converter will do better at the track? I daily drive my truck,occasionally tow a trailer (will be towing a bass boat on regular basis in the future), and I like to go the track pretty often. I'm leaning towards the 1058 but what do you guys think? Will it work good on a stock turbo truck? Thanks!
Mike Dmax
Old guy
Apr 16, 2013
23
Kentucky
From everything I've read, the 1056 is a good all around converter. If you can contact Mike L. He will steer you in the right direction.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
56
belvidere,ill
I know it would be great for the vvt, the stocker 475s usually spool pretty good But hopefully Mike will chime in or you could call Suncoast and see what they recommend.
Andrew is the Suncoast rep on this site also.
paint94979
Beer Nazi
Sep 18, 2006
11,714
Ya what's wrong with a 1056? Its a great all around converter. From friends that run the 1958 they either love it or hate it.
227
1057 has a pretty low stall (1800 rpm). This wouldn't be too tight for twins?
i've been towing heavy(26k gross) with a lower stall then that (1500).. it will load the stock charger allot better, moves the truck off the line very nicely especailly if you/your tuner tunes for it :thumb:
once you are going stall doesnt play into things near as much as getting off the line ie in then 0-30mph speed range
diesel53
Sep 16, 2010
907
AZ
No one has established a rating by fluid coupling and stall yet?
Im curious to see it laid out.
