Hey Brayden
Gasuout
Johnny
Mar 20, 2008
2,188
Santa Ana , Ca.
part of the reason it cleaned up so quick is I forgot to turn the lift pump on :eek:
I think its time for me to add a lift pump . Even with the 2 cp3 , I think I will give in now and add a lift pump . :mad: I hate electric pumps ..... never trusted them and have had many failures in the past on gas motors .
Its time though I think .
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
57
San Angelo
Go with the FASS and a Hellmann Sump :D
Fat_Robi
I may be wrong, but...
Sep 7, 2008
232
Las Vegas, NV / Provo,UT
If you hate electric pumps then go with a Mitusa.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Johny get a lift pump , i ran my truck for a week with dual cp3's and no lift pump , def noticed more fuel once i added the lift pump , but depends on the size of tunes your running too though .
X3 on the MITUSA
Gasuout
Johnny
Mar 20, 2008
2,188
Santa Ana , Ca.
Ive been considering them all lately Robi .
Trent you know I run big tunes , so I am sure I would benefit from a lift pump and the extra length of time I demand fuel over you guys being heavier and long full throttle passes in seconds of demand. Especially at glamis going up Oldsmobile . Just was never to worried about it in the past and my racing just for fun .
No where to put mitsua with my 2nd cp3 there I thought . Or is there a place ... not looked into the mitsua much ?? Thought it went where the 2nd CP3 pump went on the trucks I have seen it on in the past . Not sure i have room under hood there either . That is even bigger hassle to me really adding more to the belt system . I just need to break down and go with a lift pump I guess . I will make a bypass so if it takes a crap I can just open a ball valve and let it bypass the pump and pull the fuse till fixed if ever needed . Figured I would wait in hopes the pumps just get better and better . Just did a install on a friends Ford with the Fass and really liked the pump . Pretty nice set up the fass and looked very high quality . Ive been checking everybodys pumps out lately .
Helped semperfi with his Airdog too ... well fixed all his leaks LOL . What a mess diesel can be and turn the undercoating on trucks to tar like goo . Its nice also but liked the fass a bit better . Airdog did come with a nice harness but so did the fass . For the kodiak none of that harness will plug right in though and would have to be altered on any . Plus its 6 ft farther back the tank than 2500's . LOL . Im looking into it now and I guess will give in to my dislike of electric pumps .
Something i have always recomended to guys installing lift pump is a bypass so if you ever lose a pump you can pull over and open ball valve in place to a bypass line teed in on each side of pump already installed . Then just pull fuse to it and roll again to get home and while it is out for replacement or repair . Many friends have called me on the side of the road towing and dead pump and I say I told you to install a bypass and this is why . A good little feature to install a bypass and very easy to do when installing elec pump .
Expensive little set up the fass , but seems worth it it when you see the quality of it . Heavy sucker too .
What are the best lift pumps out there right now ??
Anything new hit the market lately ??
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
39
Windsor, Ont, Canada
Maxx'd Out twin CP3 will not stop you from adding a mitsua it has been done.
Talk to Subman about the set up on Max'd Out hell they will be running 3 CP3's and a mitsua. So I am sure he could point you to what you need.
Akdiesel
IFS Hater
Aug 23, 2009
2,213
Fairbanks
Nice pull Johnny congrats. Bummer I couldn't make it up. If you want I found a thing to pull YouTube videos to your computer.
