Allison 5sp: Have a couple of trans codes that just popped up.
Henry95
283
P0721-output speed sensor performance
P0726
I just had the TCM unplugged as I rinsed out the rad from the backside. Can anyone point me to a solution or what I should do next. Trans level is good.
Henry95
283
I checked the input speed sensors and they are plugged in and tight.
Henry95
283
Sorry for the lack of info. I basically lost forward but still have reverse. I had just left home so I backed up all the way home.
Henry95
283
Checked codes again this morning and I am showing a few more.
My normal EGR codes
P0500
P0700
-P0721
P0802
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Since you just had your tcm unplugged, and it was working fine before.........
I would say check the pins in the TCM connector. You probably have a pin that is partially backed out, or one that has gotten loose and isn't making good contact.
Henry95
283
Pulled out put speed sensor plug apart and it was green. Cleaned that up and everything is good.
DieselDean
Jul 19, 2016
Having same issue
Which sensor is the output shafts speed sensor. From what I've searched it's on top of the transfer case in the 4x4s but I'm looking at 2 sensors on top one towards the front of the transfer case and one in the rear. I'm assuming it's the one closest to the drive shafts but part of me thinks it's closer to the output shafts of the transmission not the transfer case. Any advise?
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
If it's a 4 wheel drive it's in the rear part part of the transfer case.
2wd is in the rear most section of the transmission.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
P0726
Remember WD-40 (Water displacement formula #40) has worked for years on this type of problem where water infiltrates when washing.
