Glock RMR Milling Alternative
2,176
My budget alternative to milling the slide for a red dot 😁. haven't fired it yet to see if the added weight will effect anythingIMG_20221210_210854-01~01~01.jpg
2,176
I want to try out the Recover Tactical 20/80 Stabilizer brace on it so that was my main reasoning for doing this. the stock sights are too low with the brace so I wanted something higher. I already had the Holosun HS403C and wasn't using it on another firearm so I thought I'd give it a try
N2BRK
2,055
373
I have milled and non milled firearms for red dot mounts, and I’m not sure that you’re going to like that being up so high.
2,176
brace showed up in the mail today. scope height seems to be comfortable. now I just need to go text test it without using up any ammo 😂
and folded up
1,096
only if you don't get caught. 😁. actually we should be careful saying that, for fear of giving them more ideas 😂
but now that you ruined it for me. I'm going to have to fix the typo 😝
Sadly this is true. And the same thought came to mind as I was typing it... 😥
Reactions: 2004LB7
