Gearing
PACougar
2,105
40
El Dorado Hills, Ca
Mika, I think you would be fine with 3.42 as long as you run at least a 32 inch tire. What kind of RPM are you looking at turning by the end of the run?
Mika
Bastardo Finlandias
Oct 25, 2008
291
Finland
i had around 3800 rpm in finish line at 138 mph in quarter. But it was with slicks, my street tires are smaller in diameter.
I would like to keep engine rpm under 4000 in line at mile.
PACougar
2,105
40
El Dorado Hills, Ca
I think you need to decide on a tire height to really make up your mind on gearing. 32" tire 4000 RPM you're doing 157 mph, put on a 35" tire and you'll top out at 172 mph. I know your truck has a lot more than 157 in it, so you'll either need a really tall tire or have you considered a 6 speed valve body upgrade? If you had the 6th gear you'd be able to hit 180 mph at 4K with 32" tires.
Mika
Bastardo Finlandias
Oct 25, 2008
291
Finland
I have Duraflite, not Allison so 6-speed it out of question.
But how is it with gear vendor, it will give needed gearing?
PACougar
2,105
40
El Dorado Hills, Ca
Just got done looking it up:) I would be weary of the gear vendors unit holding the power, but I'm no expert on their products. Do you know what size tire you are going to run? I think if you run a 32" tire you still might be ok as is. .69 bumps you to 161 mph and if you're willing to turn a little more 4250 get's you to 172 mph.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
I put a Ford 9" axle under the back of Casper for the second year. 2.50:1 gears are cheap.
But it would go over 175 mph with 3.42's and Allison.
Toyo Proxies are 18" rim, speed rated at 32.4" diameter. Those are what I first used. Later I ran specialty tires.
COMP461
Diesel Pro
Apr 29, 2008
429
Aledo Texas
there are many calculators apps on any phone.
The gear vendors is bullet proof .
If you going to go Mile racing it is a cross between Drag racing and LSR. I went 167.88 with Diesel Powers Project X diesel using a nine inch ford and 3.20 rear gears with a Gear vendors
the toyo Proxies are good times I use the 245 45 20's on X and it worked well. I would never advise a tall 4X4 tire, too much side wall, and if you blow a tire your dead.
you are required to have a speed rated tire at all of the mile events
here is the tire and wheel combo
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
We are currently beating the crap out of a GV unit, no issues so far. We do have the race version GV as a backup if the standard fails. We keep tabs on the fluid, and change it every other pass.
COMP461
Diesel Pro
Apr 29, 2008
429
Aledo Texas
I use to go the other way , on gearing with the GV unit on gearing . In project X I ran a 4.56 or 4.88 rear gear with a 28 tall tire . it was good for 1.6's 60 foot every time
PACougar
2,105
40
El Dorado Hills, Ca
I know my truck with 3.42 and 305/50R20 at 4700rpms in 5th gear is 162mph! I would love to do the standing mile in my truck!:thumb:
Mark, I think you'd run out of RPM's in the mile, your truck wouldn't have a problem finding 162! You need to find yourself a 1/2 mile event and go show some exotics what a fast truck looks like. Plus there's a lot lower chance of blowing up in the 1/2 mile.
