Having an issue with my 2011 LML today. Coasted up to a stop sign and the abs and brake lights came on on the dash, when I got stopped the engine started surging up and down and then died. I turned the key off and restarted, it idles fine in park and does not surge, as soon as I put it in drive, reverse, or neutral it will surge up and down and then die. I disconnected the abs module-no change. I checked all battery connections-ok, the batteries are less than 6 months old, voltage is just over 14 at idle. I pulled the fuse panel up to check for any corrosion on the connectors, its clean. I haven't checked for faults yet but will in the morning. Just wondering if anyone has ran into this issue? Thanks
